Barkbusters options.
Stephen H
Hi has anyone fitted aftermarket levers with Barkbusters and if so what make of levers did you use.
Cheers Steve
Yes i bought some china levers for the MT07 and they fit, im running Barkbusters also!
Hi Bad Pritt thanks for that information. Were they an ebay purchase. Any chance of some pics with them all fitted to your bike please.
Cheer Steve
FZ16 2011-2015. YZF R125 2008-2011. FZ6 2004-2010. FZ1 FAZER 2001-2005. FZ1 FAZER/GT 2006-2015. YZF R15 2008-2016. YZF R3 2014-2020. Example: If you own a bike of YZF R6 2003,and confirm it is one of the models above.
BB01.thumb.jpg.36fe32cc595aa175f666361347218882.jpgBB02.thumb.jpg.f6f1051203aa3405490e541be0c27d80.jpgBB03.thumb.jpg.46a6fd7f8ba2178961c4742bcee9b9fc.jpg
Bad Pritt thank you for that it very much appreciated.
Cheers Steve
Hi, I fitted some after market levers,  and I have Barkbusters...all good but two things I found...I bought the short levers and found the brake one fine,  but the short clutch lever a bit uncomfortable.  Your fingers tend to pull against the ball on the end of the lever...so now I have 1 short and 1 long!! Works for me. Also where the bolt goes through the lever there is a metal bush/ spacer you need to swap over.  Cheers,  Steve
I have the adjustable (and folding) levers from Off-the-Road. And they fit just fine.
