Hi, has anyone got any tips/advice on fitting the SW Motech lower engine bars...? Cheers,  Steve
In my opinion the documentation that comes with it is very complete and you can just stick to it.
I felt it fitted perfectly, with no problems whatsoever to install it to the bike.
What I did though, was to install it completely first without using bolt adhesive and then pull it apart again and start all over with the screw securing when I was sure I knew what I was doing. But if you're more experienced as me you probably won't have to do so.
edit: I torqued the screws to the general figures indicated in the sw-motech documentation
Edited by qInvention
