Posted April 12, 20205 yr Hi, Thinking about procuring or making blanking plates for the pillion footrests. Anyone have the center to center measurement of the mounting points of that bracket? Thank you.
April 12, 20205 yr 1 hour ago, Scaryfast said: Hi, Thinking about procuring or making blanking plates for the pillion footrests. Anyone have the center to center measurement of the mounting points of that bracket? Thank you. Why do you need blanking plates? You can just screw shorter bolts in the threaded holes or even plastic plugs to keep the dirt out and threads clean.
April 12, 20205 yr Author 1 minute ago, Whitey66 said: Why do you need blanking plates? You can just screw shorter bolts in the threaded holes or even plastic plugs to keep the dirt out and threads clean. The plate I'm considering has an eyelet to accommodate the strap from my rackless luggage.
April 12, 20205 yr 15 minutes ago, Scaryfast said: The plate I'm considering has an eyelet to accommodate the strap from my rackless luggage. Ok, i'll go measure it for you now👍 Edit: It's 70 mm Edited April 12, 20205 yr by Whitey66
