Found this on Instagram but I'm not sure what it means for the cp2... Looks like the pipes for the pump are gone and he is highlighting a carbon canister.
Any ideas?
Electric water pump, the owner answered 🙂
@T7insta do you have more information about this mod.. Supplier cost and benefits?
Regards,
Aleks
Yes, Monzatech is going to market it, I leave you the link to its website. Although it is not yet available and we have no price.
I kit plug’n’play sono invece dedicati ad uno specifico modello di moto poter dialogare direttamente con la centralina motore e poter essere installato utilizzando gli stessi connettori della moto originale. In questo modo la gestione elettronica della pompa...
Thank you... Let us know when it is ready... I'm not interested as my bike is road only but I'm sure there are plenty of owners here who are more hardcore and would benefit from this mod.
Aleks
Howdy,
I am curious, and I'm scratching my head, what is the benefit of having an electric water pump?
Tazmool
  • Community Expert
Just now, Tazmool said:
Howdy,
Tazmool
In the dirt, on trails you are often barely moving while going over and around obstacles and around switchbacks, at low RPM.  Which means the water pump is barely working, not cooling the engine to the full extent.  Electric water pumps are not dependant on engine rpm.
Ahhh!
That makes sense.
Thanks for the info!
Tazmool
a solution without a problem.
Never heard of this bike or engine overheating, or water pump failing/breaking. when is the radiator delete coming, then the handlebar delete, then the fairing delete, just delete everything that could give a problem
  • Community Expert
Do you ride much 5 mph or less trails in the heat? Its an issue on Dirtbikes on single track in the summer.
Has it been a problem on this bike? If it has, I'm not aware. It's not a dirtbike, or a high stress engine, maybe living Canada where it's always cold we don't notice or care lol
Edited by ScorpionT16
