T7 Fork oil capacity
Tom
Can somebody please tell me what the fork oil capacity and viscocity should be? I can't find it anywhere!
Thanks in advance
Tom
I tried a search for it and no luck.
KTMmitch  is John from Rally Raid.
If he doesnt see this and respond try shooting him a pm
If you use search on this site there is a T7 workshop manual. It says....
Making James May look quick!
It is preferable to use Oil Height, rather than volume, as it is more accurate, as unless the forks are stripped and cleaned completely to remove old oil, then you can never be sure
We set the oil height with no spring or spring guide (the long white plastic tube), and compress the forks so the inner & outer tube tops are flush (careful not to compress further as the top inner bush can "pop" out of its recess and the jam the outer tube, and it's very difficult to get back in !!!
We used 100mm air gap, so the oil level was 100mm below the top of the fork tube. 10W fork oil.
Edited by Ktmmitch
Thanks to TimG and Mr. Mitchinson.
 I was hoping to get this information too.
  No real rush tho.
I’ve found a supplier on this side of the pond for springs.
 I enjoyed viewing the MAD video on set up and appreciate rally raids contribution!
