side stand switch
today i mostly......sidestand switch delete completed. cut a soldered wires together an awful lot easier than trying to find the connector hidden up by the radiator. clutch switch next on my list.
just a note. be gentle with the cable tie holder type plugs that fit into the lower frame tubes.if you snip the cable tie they are then u/s.the plug/holder is part of cable tie.
Done the same on mine... Work brilliant thanks to @Camel ADVfor sharing his video
