Posted May 27, 20205 yr Simple seat mod, I saw this on a Aussie site so not my idea. Like most of you probably, I hate the way the front seat screws in to place. It’s a pain just getting the Alan key out. All you do is drill four small holes for a cable tie and two small pieces of rubber hose. As you can see in the picture. The rear seat fits as normal and it locks the front section in place. Job done.
May 27, 20205 yr Nice mod 🙂 .. thank you for sharing... I will be getting the rally for mine otherwise I would have done this 😄
June 1, 20205 yr On 5/27/2020 at 4:33 AM, Chalk said: Simple seat mod, I saw this on a Aussie site so not my idea. Like most of you probably, I hate the way the front seat screws in to place. It’s a pain just getting the Alan key out. All you do is drill four small holes for a cable tie and two small pieces of rubber hose. As you can see in the picture. The rear seat fits as normal and it locks the front section in place. Job done. Moving this to tech tip section so it doesn't get buried and lost in general discussions. So people can find it later. The MT-07 forumThe Tracer 900 ForumThe MT-10 Forum
February 24, 20214 yr On 2/19/2021 at 7:35 AM, 29er said: i just unscrewed the two allen bolts and screwed them in again but from underneath - its a bit of a fiddly job but once done the seat then sits on the protruding ends of the allen bolts that come through to the top, you simply pop the seat over the pins and thats it, the rear seat holds it down without any other fixings at all I did this. Works well! I am using this method with the Blackdogcw.com Helo Pad and I can confirm it works, no slop or rattling.
February 26, 20214 yr You guys seen this? seat hack for the T7 YouTube - RIDER GUIDER - check out my T7 playlist and say hello 😀
April 19, 20214 yr I am using the upside screw method as well, turned two screws into two studs works perfect
