Cyclops Adventure sports LED plug and play kit
PNWTEN
The bike is currently at Cyclops lights in Kent Washington getting mounts and brackets for the
Looks cool. I was curious about these lights but they don't have flood nor wide pattern for this.
Can you please share some more photos like bracket, switch etc.
The bike is still at Cyclops lights, I go pick it up tomorrow. Will take pics of all functions. Expect a blog post at www.tenereacrosstheusa.com also.
the bracket is the prototype, the final version will be about 1/2” closer and upward toward the center. The white center of the light is tied into the high and low beam. Low beam is set at 50% and high beam at 100%. They are totally programmable if you want it another way. You’ll have to get with Cyclops to figure out what you want.
All this will be in my blog post soon after I get some night shots tonight to show how powerful these really are.
Those are 30’+ cypress trees. 1 st is just headlights on low beam, 2nd is low beam with Aux lights on low. 3rd is everything on high beam
@PNWTEN Thank you for the information. I will be looking forward to see final production version of the bracket. Is it steel, powder coated ?
Edited by Takata
I have tried visionx LED. model:dura mini combo. 2 x 20w and an incredible result !
in this video you can see difference between origin, chinese led and visionX LED... 😉
@PNWTEN is cyclops planning on doing anything T700-specific with the multifunction turn signals? Or are those already generic enough that they sell “plug and play” kits?
Powder coated steel.
Blog post is done!
328c9e91-af74-455a-8ff6-48a394173392.jpe
Darryl VanNieuwenhuise and his team from Cyclops Adventure Sports have been patiently waiting to get ahold of my bike for weeks now.  You see, they only had a little bit of time working on a T-700 with Cory...
Thank you! I had ordered a set of the Cyclops Aurora lights about 2 weeks back, is there anything different about the T7 kit aside from the bracket? Will there be instructions on how to tap into the high/low beam? And did they manage to get the orange halo to work as a signal alongside a DRL?
That’s specific questions for their crew, give Darryl and Sandra a call. They are top notch in customer service!  Tell them hi for me!
I just gave a call to Daryl at Cyclops.
High performance LED lights & accessories for motorcycles, autos, snowmobiles & more. Exceptional customer service. U.S. based. Worldwide delivery.
He's going to be making specific light kits for the T7 in the future including the Aurora and optional signal lights. 🙂
I cannot recommend this company and lights enough, I just went with the non-specific T7 ones, with a separate switch. The halo is very bright, hard to show, I used OEM Fog lamp brackets.
On 6/16/2020 at 9:35 PM, PNWTEN said:
Some daytime pics
I am more interested in your turn signal setup. Most importantly how they are mounted to the fairing in the oem hole. I have looked at Cyclops but was totally confused on what I needed to buy. Rear signals I think I can just mount them on any tail tidy without the use of adapter backing plated like the fronts. I have to get rid of the oem big orange ones soon. Any info to share on the signals is much appreciated.
Cyclops is making a kit for the T-700, this is the prototype. The best way to get all your questions answered is a call to Darryl, Sandra or Tarrin. Super helpful. Tell them hi for me!
They are mounted using an adapter, its a generic size and works on 99% of all these after market LED signals, Amazon, Ebay etc... all have them
Quickly and easily secure your LED Pod Signals to your motorcycle with the easy to install Plate Bracket Kit. Shop TST Industries today!
What relay flasher is used? two pin similar to Mt-07 that TST sells?
Fix your bike's hyperflash or no flash problem with an easy to install, direct replacement, plug-and-play Gen2 LED Flasher Relay.
Edited by roy826
Yes, 2 pin. I changed all 4 to LED with the relay, though... The dash signal light no longer blinks, just stays light in the signal direction, the signals all blink fine, I think it's something to do with needing a resistor on the rear ones
Edited by ScorpionT16
Are your lights connected directly to the battery?  Do you have a photo of your switch setup?
9 hours ago, Toei said:
Where does the T7 Aurora kit plug in/connect at on the bike?
There is a 3 pin accessory plug that is capped from the factory located under the left hand side fairing. You remove the caps and wire it into there, 2 pin standard or add the third pin for Daytime Running Lights version. The T7 kit comes with everything you need to not alter any of the original wiring, apart from a posi-tap wire to tie into the highbeam power.
