Cyclops Adventure sports LED plug and play kit
PNWTEN
1 hour ago, tenerecanada said:
There is a 3 pin accessory plug that is capped from the factory located under the left hand side fairing. You remove the caps and wire it into there, 2 pin standard or add the third pin for Daytime Running Lights version. The T7 kit comes with everything you need to not alter any of the original wiring, apart from a posi-tap wire to tie into the highbeam power.
Excellent, thank you!
I just ordered their T7 LED 2.0 signal kit. Said on back order but I hope not to much longer.
Edited by roy826
Mine shipped today so I'm guessing they are sending them as they can.
How long ago did you order your kit?
My order arrived today.  I only had time to do the front lights.  Had to call Cyclops for assistance. The flasher relay connector was not wired correctly so it took about 45 minutes for me to dig the pin out and position it correctly.   I cannot say I'm happy about having to spend the time screwing around with the relay though.  I paid the extra money vs Amazon not to have trouble like this.   Otherwise front lights are nice.  Not sure when I'll tackle the rear lights.
  • 4 months later...
Just ordered the kit.
What's the verdict on them? Kinda expensive, hopefully worth the cost.
I like them.  If I had to do it over again I probably would have gotten them off Amazon instead but so far everything is still working as it was when first installed.     I'm sure by now you've already got them installed though.
Got mine installed. I’m thinking they recently changed the t7 kit. All crimped plug and play connectors (no bullets)  and upgraded signal attachment.
I’m happy.
