Adventure spec rear rack with Givi topbox
Rich TT
For those that want to run a Givi topbox with the Adventure Spec rear rack, it's absolutely possible.
I bought a genuine universal Givi Z113C2 mount for only £20 from sportsbikeshop.co.uk. I didn't have to drill anything at all and the mount was secured with the provided brackets and I used stainless Allen bolts and stainless nylox nuts.
I tested it out with the rally seat and I can still get the seat off and there's plenty of room two up with my old Givi topbox fitted.
I will be using this setup for commuting only and switch to soft luggage for adventure riding.
Hope this is helpful to someone.
Rich
  • Confused 1
The issue is that's no room for passanger...
But looks very good...
There is room.
I'm tall and so is my daughter and we "tested it out" last night in the garage and there was plenty of room. Admittedly not on the road, but it seemed fine. With the Adventure spec rack, you don't want the passenger sitting right at the back anyway to avoid bum/thigh/rack interaction.
Cheers
Rich
Ok... But for a women... It seems short for a trip with Confort, this one is myne, but probably have more space, but that's only what seems...
I just ordered the AS rack to use with my SHAD case. Glad to see it all works out
Rich
🔝🗃️🤮🤓😝🤣🤣🤣... Looks amazing.. Cannot wait to turn 50 myself and get one of these... Me and @Rich TThave this joke and I had to hijack the thread to keep the spirits on a high note 👍😂
Anyone fitted one of these with the adventure spec rack? 👍🏼
  It looks good RichTT.
Another option for a Givi  Monokey on this side of the pond.
Altrider pin and lock kit and Tusk tail rack. image.thumb.jpg.a53c07322ab3daea3390ec153e39f9ee.jpg
So what is the weight limit for an AS rear rack? Didn’t see any weight limit mentioned on their website, when I bought it.
13 hours ago, Buba said:
T700%20Luggage%20Rack%20Forces%20Digram%
Chris Colling explains why you shouldn't overload your T700 rear top luggage rack.
Apparently this happens when you overload it.
Interesting. I've only used my Givi top box mounted to the AS rear rack for commuting to work. All it has in it are shoes, shirt, trousers, lunch and a lock so nothing near the weight of the 1 gallon Rotopax that AS recommend is OK. I also would never take it off road with the top box on.
But this is a really good reminder not to load up a top box on the AAS rack and many thanks.
For proper travelling/adventure, I ditch the top box and fit the brilliant Enduristan luggage.
Cheers
Rich
Hi from Italy,
yesterday evening I mount my GIVI SR2145 and the GIVI M9B plate.
Cheers
Rich
Hey Rich,  that's exactly how I intend to use mine. I'm sure we'll be fine!
I found this photo on local tenere group and saw it was used with large aluminum top box.
EMGO box mount fits on an AS rack without drilling also.
2021 Yamaha Tenere 700
2019 Husqvarna TE 250i
2018 Husqy/Oberon/JD FE 450
Yet again another reason to avoid Adventure-Spec... crazy. And people here are turned off on Levers from China... laughable.
I also have the Adventure Spec rack on the rear of my T7.  Was concerned about fatiguing the aluminum after I mounted a Pelican type box on back.  Added these struts to alleviate my concern.
