Posted July 2, 20205 yr Just wanted to share this, just in case some of you didn’t know. These grips has 3 different settings. Just hold the button down 5 seconds, and the light flashes(if it doesn’t, turn off and on the ignition while holding the button on the grip). For more heat in the grips press the button so that all lights flash. Then wait 5 seconds, and you’re all set. I didn’t know this before my dealer told me. Stay safe🙂 Edited July 2, 20205 yr by Magz
July 2, 20205 yr Yeh i saw that but mine works on 1-2 or 3 with out doing that. What does the holding the button down actually do as works well with out, i can see it increases the power but im guessing it draws low current out of the box? Edited July 2, 20205 yr by Matth
July 2, 20205 yr Author 2 hours ago, Matth said: Yeh i saw that but mine works on 1-2 or 3 with out doing that. What does the holding the button down actually do as works well with out? Well if i understand your question right. These programmes/modes alter the heating effect these grips have when you use them. I thought the ones on my old bike didn’t give as much heat as i wanted. So my dealer did this procedure, and they became warmer. They work exactly as before, but are slightly warmer. Edited July 2, 20205 yr by Magz
July 2, 20205 yr 40 minutes ago, Magz said: Well if i understand your question right. These programmes/modes alter the heating effect these grips have when you use them. I thought mine on my old bike didn’t give as much heat as i wanted. So my dealer did this procedure, and they became warmer. They work exactly as before, but are slightly warmer. Hi Magz. Thanks for this. I posted on this a while ago and found out by chance about the different settings for big CC bike. When I did that they were a lot warmer, although nowhere near as warm as the Oxford ones. But they look much better. Cheers Rich
July 2, 20205 yr Magz, your a genius! Tried it and within 15 secs or so the heat is higher and after 3-4 mins they are significantly hotter! this is your good deed for today!
July 2, 20205 yr Author 1 hour ago, Rich TT said: Hi Magz. Thanks for this. I posted on this a while ago and found out by chance about the different settings for big CC bike. When I did that they were a lot warmer, although nowhere near as warm as the Oxford ones. But they look much better. Cheers Rich Hi Rich. I’m a newbie around here, so i didn’t know if it has been posted before. I agree with you, the oxford grips are hotter. But the look on the OEM is sleeker. Stay safe🙂
July 2, 20205 yr Author 1 hour ago, Matth said: Magz, your a genius! Tried it and within 15 secs or so the heat is higher and after 3-4 mins they are significantly hotter! this is your good deed for today! Awesome! Glad to help😉 Stay safe🙂
July 2, 20205 yr 52 minutes ago, Magz said: Hi Rich. I’m a newbie around here, so i didn’t know if it has been posted before. I agree with you, the oxford grips are hotter. But the look on the OEM is sleeker. Stay safe🙂 Agreed mate!! Enjoy your bike. Love mine.
February 13, 20241 yr Wondering why mine didn't work and have been checking fuses etc - hold down for 5 and all good!
