Fuel tank Removal
Gary b
Most home mechanics won’t have a problem but for those unsure this is how I did mine
  • Thanks 2
9 minutes ago, johnnygolucky said:
Pro Tip: take some anti nausea medication before watching video.
Didn’t take long for the keyboard warriors to get their kicks😆
  • Haha 3
That's very nicely explained... Thank you for making this... I will be removing the tank soon to fit some nice stuff on the bike... Could you please tell me how much room is there to be had in the front next to the steering stem if I wouldn't remove the fuel and cable connectors... Can I pull the tank back 50mm or 100mm?
Aleks
Aleks
Sorry I’m not sure how much you can pull the tank backwards while the pipes are still connected
No worries, I will check when I get to that point.. I'll remove if needed doesn't seem complicated anyhow.
Thank you 👍
Aleks
yes you can.
