Vtamb81’s build and records
Vtamb81
Bike received on 7/22/20 at 1 PM at Wayne’s Cycle in Waynesboro, VA. 0 miles on the odometer.
7/25/20. Decided to do an early oil change to remove break in metals from the oil at 100 miles. Changed oil (Yamalube 10W-40) and filter (Yamaha). Fine metal particles typical of engine break in were present.
7/30/20. Mods to date. 441 miles.
- CamelADV skid plate
- CamelADV anti-bobble head
- CamelADV Tail Tidy
- Barkbusters Hand guards
- Yamaha Aluminum radiator gaurd
- Yamaha chain gaurd
- T7Rally Sidestand switch delete/bypass plug
- T7Rally seat joining kit
- TripleClamp engine/water pump covers
- Rally Raid SS wheel spacers
- Justtech LED signal lights
- SAE connector to battery
- MZS shorty adjustable levers
- double take mirrors
Edited by Vtamb81
600 mile service (less the oil change which I did myself) performed at Wayne’s Cycle on 8/13/20. Oil changed with HiFlo filter and Yamalube Semi-Synthetic 10w-50.
9/12/20. Additional mods to date. 1200 miles.
- Rally Raid 90nm Linear rear spring
- Rally Raid nylon fork guard screws
- TPMS sensor in prep for tubeless conversion
- TechSpec snakeskin nonslip panels
- Outback Motortek rear tail rack
Edited by Vtamb81
9/23/20. Additional mods to date.
Replaced the stock 5.9nm front springs with Hyperpro progressive springs (6-9nm). Upped oil weight to 10w from 5w.
installed Yamaha heated grips
Edited by Vtamb81
12/11/12: additional mods to date. 2500 miles
- Adventure Spec Crash bars and side luggage racks.
- Highway Dirt Bike top clamp with powerlet mount (for heated vest)
- IMS enduro Pegs
3500 mile update:
- yamalube full synthetic oil/filter change
- dual usb/voltmeter replacement for 12v plug (hardwired)
- CamelADV high exhaust
- OUTEX tubeless conversion and balance
- Michelin Anakee Wilds
Edited by Vtamb81
3/22/21 update:
- MWR foam filter
-MOB UP Design filter lid with prefilter
- 2WDW ECU flash
I need to stop! 🤣
