Rally Raid Soft Luggage Rack
ride2little
Since they attach similar to the Adventure Spec sideracks, I'd say they would be compatible with the AS rear rack.  You would likely need a longer mounting bolt.  The AS side rack uses a 60mm bushing on the front spool mount and a 40mm mount on the rear.  From pictures on Rally Raid's website the bushings/spacers they use to mount their rack may be 46mm or 48mm.  The AS siderack uses the AS rear rack as the spacer so with Rally Raid's mounts all being 46mm or 48mm, you could just add spacers and longer bolt to mount the RR Side rack to the AS rear.
The B&B Compact rack might work as well.
Lacking actual real world answers, yo could ask RR their spacer height, them find the rear rack you want to use, ask for measurements of the rack mounts to see if the Rally Raid mounts are at lease the same or longer.  If so then you should be able to make it work.
J
