Posted October 9, 20204 yr So after trying to find a solution to find a midpipe to fit my old Triumph’s Yosh RS-4 pipe onto my T7, I finally found a very simple $30 midpipe that works without issue and once setup looks like it was made for the T7. check out the photos stock pipe weighs 10 lbs yosh rs-4 with heat shield 7.5 lbs saved 2.5 lbs or about 1 kg This is the midpipe I purchased Honda CB1300 2003-2013 https://a.aliexpress.com/_mL1W4QF The OEM heatshield was used by adding 2 clamps, drilling a hole and adding nuts to secure the shield, then clamp to the midpipe Midpipe clamp to manifold I used the oem gasket and had to add some high temp silicone due to very slight gap. Once cured, I clamped it tight and no leaks and very secure 51mm exhaust to midpipe so as long as your exhaust is a 51mm, it should work. The yosh pipes mount aligns perfectly with the T7 Very pleased and sounds amazingly throaty, almost like a thumper Edited October 13, 20204 yr by Lyfe BehindBars Adding more info on this mod
October 9, 20204 yr That's wonderful Lyfe. Bravo. If anyone else scours the internet and after months of investigation finally figures out how to do this then feel free to share your photos here too. 😐
October 13, 20204 yr Author On 10/9/2020 at 8:40 PM, Stevoh said: Where did you source the mid pipe, and what bike was it originally made for? I updated the post with more info
October 13, 20204 yr Author On 10/9/2020 at 9:56 PM, ride2little said: Lets hear it! On 10/9/2020 at 9:56 PM, ride2little said: Lets hear it! Can’t upload a video file but sounds awesome, more throaty, sounds more like a thumper
October 13, 20204 yr Author On 10/9/2020 at 7:25 PM, TimeMachine said: That's wonderful Lyfe. Bravo. If anyone else scours the internet and after months of investigation finally figures out how to do this then feel free to share your photos here too. 😐 I updated the post with more info
October 13, 20204 yr 4 hours ago, Lyfe BehindBars said: I updated the post with more info Thanks for the info, Im using a link pipe for Honda cb500 also sourced from Ali express, fits reasonably good but the angle is slightly off, not so bad with a shorter slip on muffler, 350mm, but I'm looking at fitting a longer type so I'll purchase the CB 1300 link pipe,looks like a better fit.
October 13, 20204 yr Author 1 hour ago, Stevoh said: Thanks for the info, Im using a link pipe for Honda cb500 also sourced from Ali express, fits reasonably good but the angle is slightly off, not so bad with a shorter slip on muffler, 350mm, but I'm looking at fitting a longer type so I'll purchase the CB 1300 link pipe,looks like a better fit. keep in mind its 51mm both sides
