Tap in point for auxiliary electrical accessories
PDanger
I can no longer find the post but someone inquired about a suitable point for tapping into the live feed without it being permanently live as with a direct battery connection. I took my live feed from the blue & white - headlight feed - which is live only when the ignition is on. I've wired this to an Innovv 5-way adaptor (~ 50 GBP).  The Innovv device turns on and off with the ignition with a 10 second delay. The image isn't good, too many things to hold and prod with one pair of hands.  The feed comes from a module at the rear of the battery which I've tapped into with a red Scotch lock. The key points toward the blue & white wire.
It works too!  I've wired my Oxford heated grips, auxiliary power USBs & cigar lighter, Tom Tom 550 and still have a couple of feeds spare for lighting if required.
Heads up.
Maximum wattage per device is 5 w,  maximum overall for the Innovv is 20 watts (I believe).
