Quick release fasteners
Vtamb81
Does anyone know of quick release fasteners that will work on the front side panels of the T7? I love the AS crash bars but the lower portion blocks the bottom side panel fastener, making it really hard to get a tool in there.
After looking at options for quick release fasteners/spring nuts I think I will end up going the thumb screw route. I haven’t been able to find any quick release version that will work.
Now I just need to find a good M5x10 to replace the stock bolt.
https://www.mcmaster.com/screws/thread-size~m5/length~10-mm/thumb-screws/
  • 9 months later...
I have the same issue with removing that bolt since I also have the ADV Spec crash bars.  I have found that a 8 mm ratchet wrench does the trick for quickly removing that bolt in the panel.  Let me know if you settled on a solution.
I bought some cheap ones off Amazon. I'm not sure about the fairings on the outside, but size 19mm work for the bottom 2 screws on the inside near the radiator. So about 4 total. The top one would work I guess if you dremeled the tab, but that was too much for me.
