°F to °C
JMRS
Hello,
In Chile we receive the US model ( made in Japan ), so the temperature on the dashboard shows °F.
The Yamaha importers says it can not be changed to °C ( owners manual does not say how to change it either ).
It is hard to believe than it can not be changed when on European models the temperature is shown in °C ( software most likely is the same )
Anyone has any experience with this issue ?
Is the speed in mph or in km's? If in mph, try changing it to km's.
This might change the temp reading also,
Thanks for the suggestions.
Following the instructions on the owners manual. I was able to change to km/h and to km/lt.
No change to Celcius though.
The owners manual says the temperature is in °F,  and no indication on how to change it
The EU owners manual says the Air Temperature is in Celsius and does not explain how to change it.  I guess you get what you get.  Sheesh.  What good is that?
