Posted February 2, 20214 yr Has anyone managed to find and buy (in the UK) the elusive 3 pin connector? I know there are workarounds, etc. However, before I go there, Yamaha has put these connectors to be used and I would like to do so. Thanks Edited February 2, 20214 yr by Treps clarified wording
February 2, 20214 yr Motorcycle MT .090 Sealed Series - Connector and Terminals Sumitomo - HM Sealed(Mounting Bracket type) and MT Sealed type Connectors for .090 - 2.3mm Terminal. These Connector s are used highly on Throttle position sensors, Neutral Switch, Cam and Crank Shaft Position Sensors for GSXR - YZF - CBR - CRF All connectors Come complete with male, female terminals and wire seals. For... Scroll down and look for this. It may be what you're looking for. 3 pin MT .090 - 2.3mm Male and Female locking conn
October 19, 20213 yr Hey, Did you find it? If you don't check this links 3 Pin For Sumitomo Female Male Plug Connector Motorcycle Yamaha Kawasaki Suzuki Sumitomo MT 2.2 Series Sealed Male Female 3 Pin Way Waterproof Automotive Connector Yamaha 6187-3231 6180-3241. Male And Female set 1 x Female Connector Housing And Insert. 1 x Male Connector Housing And Insert. 3 Pin 3 way Sumitomo Automotive Motorcycle Female Male Plug electrical Connector 3 way pin Sumitomo Automotive Plug electrical Connector Yamaha Suzuki Honda. Sealed Male Female 3 Pin Way Waterproof Automotive Connector. Male And Female set 1 x Female Connector Housing And Insert.
October 19, 20213 yr Yamaha Super Tenere Accessory Connectors – Electrical Connection Same connector used in the super tenere. There are a few options out there.
December 5, 20213 yr I got them from Cycle Terminal in VA, USA. $5/set, $5 shipping, arrived in 3 days on west coast.
