Posted February 21, 20214 yr Took Possession June 10, 2020 from Switchback Motorsports, Pocatello Idaho. Engine Unifilter foam filter and pre-filter SC Project Ti exhaust, full system 2WDW ECU flash Suspension Rally Raid Extreme Shock with extended linkage bolt Rally Raid Extreme Closed Cartridge Fork Kit Rally Raid Stainless Wheel Spacers front/rear Motoz Tractionator Adventure, Tubeless - R = 140/F = 90 Controls/Comfort ASV Levers Fastway Air Ext pegs Steg Pegz Double Take mirrors Seat Concepts Rally Low Hard Adv 2.0 KAOKO Throttle Lock, stock set up Rubber grip pads from Paul's group buy Alt Rider Dual Control Brake System Protection R&G Case Covers AXP Bash Plate -trimmed Rally Raid Headlight Protector Custom Wrap, MARPAT Urban - Made by Sign Up, Pocatello ID Electronics Garmin inReach Explorer+ - mounted on Rally Raid handle bar clamp Garmin Zumo XT - mounted on Rally Raid 12mm bar clamp Denali Power Hub 2 USB Quick Charge 3.0 Denali D4 Light Kit - mounted on Denali T7 aux light mount Antigravity Re-Start Lithium Battery @Aleksandar13 - corrected ABS ring set (not installed yet) Luggage Mosko Moto Reckless 80L v3.0 - longer trips Mosko Moto Reckless 40L v3.0 - shorter trips Signals Front I copied @JohnnieBoy flush mounts Rear I copied @sshat Motogadget M-Blaze Pin MISC T7 Rally Tail Tidy Gilles Axle Sliders with Ti Axle Nut Primary Drive Chain Guide On Site but Probably Won't Install Seat Concepts Low Comfort OEM Heated Grips KAOKO Throttle Lock, Bark Buster Version SW-Motech Kobra Hand Guards (re-badged Bark Busters) OEM Crash Bars Cyclops multi function 2.0 Turn Signal Kit OEM Aux Light mounting brackets B&B Off Road Rear Compact Tail Rack R&G Tie Down Mounts - Removed these for the Steg Pegz (replaced OEM pillion pegs) Edited August 2, 20213 yr by Idarex Update
February 22, 20214 yr Author More on the wrap I worked with a young man, Shane, at Sign Up in Pocatello to get it exactly how I wanted it. He has the pattern now and can pretty much make anything going forward. The first one took a lot of work. Its a very durable and UV resistant vinyl that they use for dirt bike wraps. It is printed matte not gloss and is over a matte black T7. Background is MARPAT Urban camo pattern. I have various emblems of Marine units that my father/myself/sons were in or detached to. "Idarex" & "Semper Fi under the front signals. "T7 World Raid" & "I'm Ready For Beer" on each fork leg and above the rear number plates. Edited June 24, 20214 yr by Idarex
February 22, 20214 yr I have been toying with the idea of a Dazzle Camo wrap, your wrap makes me realise it's not as daft an idea as some of my mates think. Something similar to this... Edited February 22, 20214 yr by electric_monk
February 23, 20214 yr Author SC Project Ti exhaust, full system Rally Raid Extreme Shock Edited June 22, 20214 yr by Idarex
June 22, 20214 yr Author Motoz Tractionator Adventure, 140 rear T7 Rally Tail Tidy ASV Levers Fastway Air Ext pegs Steg Pegz, 2x pucks Rubber Grip Pads, Paul's group buy Double Take mirrors Seat Concepts - Rally Low Hard Adventure 2.0 KAOKO Throttle Lock, stock set up Alt Rider Dual Control Brake System Trimmed AXP Bash Plate Edited August 2, 20213 yr by Idarex
June 22, 20214 yr Author R&G Case Covers Garmin inReach Explorer+ - mounted on Rally Raid handle bar clamp Garmin Zumo XT - mounted on Rally Raid 12mm bar clamp Denali D4 Light Kit - mounted on Denali T7 aux light mount Mosko Moto Reckless 80L v3.0 - longer trips Gilles Axle Sliders with Ti Axle Nut Primary Drive Chain Guide Edited June 23, 20214 yr by Idarex
June 23, 20214 yr Author 11 hours ago, kainic said: Wow, very nice setup. Why did you end up trimming the AXP? I was having a little difficulty with the brake lever wearing Tech 7 boots. Trimming off the part of the AXP that covers the water pump helped. The dual level Alt Rider lever really helped. I also had to adjust the shift lever for the boots to work.
June 23, 20214 yr Author Signals I really liked what a couple guys did in this thread so I duplicated them; Front I copied @JohnnieBoy flush mounts Rear I copied @sshat Motogadget M-Blaze Pin Edited June 23, 20214 yr by Idarex
