Posted February 25, 20214 yr I noticed the front indicator connectors on my European bike have only two wires connected to them. I am trying to install aftermarket LED blinkers with DRL function. Where can I tap in the third wire to get current for my DRLs? Also, the rear LEDs have a brake light function. I presume I can tap in to the positive cable of the brake light to connect the LED's third wire? Thanks!
February 27, 20214 yr The front leds could be connected to the power outlet found under both side fairings. Thought of doing this myself this winter but I got lazy and moved the protect to next winter. Please let us know how this works out. "Eternally, unavoidably, eventually, all paths will lead to the cemetery." Sentenced
March 16, 20214 yr Author In the end i replaced the 2-pins AUX connectors on both sides with aftermarket ones. I soldered an extra wire on the female connector which I can connect to the third blinker wire. That way I can still easily disconnect this third wire when removing the side panels.
