Posted May 8, 20214 yr Popular Post Finally found a use for the "wasted" space in the rear fairing. Built a small removable plate out of some spare ABS with some quick release tabs. Cut a hole in the original plastic, heated up the ABS and formed it to the tail section. The quick release tabs are 1/4 turn body panel fasteners that keep the panel nice and tight. Enough room in there for an emergency bivy bag and some essential first aid gear. Items that I think should be with the bike at all times, but in the past have been left behind. Also decided to take advantage of the room behind the front body panels and make a permanent mount for spare tubes. Did have to rivet a tab on the inside to get this done. Easy enough to remove the tubes, which are tucked away in their custom made bag and strap system. One tube for each side, never going to be able to leave home without them. Been on a bunch of rides with the tubes stored in there, the picture shows they stay more than clean enough which is telling me that they are good and protected from damage. No heat issues either, the plastic holding the tube in place lines up with the corner of the rad, which still has good clearance.
October 12, 20231 yr @sshat Really cool idea! Do you hape a picture to show how much space you have inside the rear? Edited October 13, 20231 yr by DVVVDM Took the suggestion from the moderator to @. Millions unreached, none unreachable.
October 12, 20231 yr Moderators 6 hours ago, DVVVDM said: Really cool idea! Do you hape a picture to show how much space you have inside the rear? If you quote the post or add @ in front of their user name, they'll be notified of your question vs waiting for them to revisit the thread to see your question. @sshat "Men do not quit playing because they grow old, they grow old because they quit playing" Oliver Wendell Holmes - Mods - HDB handguards, Camel-ADV Gut guard, 1 finger clutch, The Fix pedal & Rally pipe, RR side/tail rack, RR 90nm spring & Headlight guard, Rally seat, OEM heated grips- stablemate Beta 520RS
October 12, 20231 yr Or you could just remove your plastics and look. Edited October 12, 20231 yr by Hollybrook
October 13, 20231 yr Author Hey @DVVVDM , nope, no picture. Other than the exhaust support bracket, that side compartment is empty. The opening is smallish, so a small bag of first aid stuff is easy to get in and out. Thankfully I don't have to get at the gear often.
October 13, 20231 yr 39 minutes ago, sshat said: Hey @DVVVDM , nope, no picture. Other than the exhaust support bracket, that side compartment is empty. The opening is smallish, so a small bag of first aid stuff is easy to get in and out. Thankfully I don't have to get at the gear often. Thank you for replying 👍 I think the idea is brilliant and the execution looks great. I'll look into doing this on my own bike 😁 Millions unreached, none unreachable.
