MotoZ Rallz tire set up tubeless
helipilotxtz700
Hi guys
 I just finished setting the wheels up tubeless! Was pretty easy and they are holding air just fine! Used the sealing Tape with out the silicone! This way I can plug a tire and not pull a tube!
Looks good!
I used the silicone first. Then the 4412n 3m ,one rap.
  so far, so good!
Did u use the 4411 or 4412?
 The 12 is thicker an might stand up to tire iron abuses better ?
I'm in the cue to do this soon.
Where/how did you position the wheel when you did yours?  Just stand it up vertical in front of you?  On a wheel balancer?  Did you need a second person for help?
I own a Tire machine! I used the 12 because it was thicker! I also didn't use silicone! The spokes were almost air tight! Did use clear Gorilla tape just to protect the sealing Tape from mounting the Tire! I didn't balance the tires at up 90 they are smooth!
I taped mine but left the tube in . its more of a backup to get me out of the woods without changing a tube if needed.
