Acc. Plugs and Pins , and Indicator Connectors
ClutchXT
Was looking into the heated grip connector harness and noticed I already have the pins to  make my accessory plugs.
Here is the links to the connector kits and pin, most of the accessory connectors are plugged with their corresponding connector type so you can get the pin and weather seal to make your own pigtails, I have ordered several pin sets from corsa for use on my other Yamaha bikes and UTVs they are always fast to ship and haven't had any issues with their products
Sumitomo MT-3P-2  3-way plug
Sumitomo MT Series connector index - the 2 pin and 3 pin variants
N38 Series Female Connector - turn signal
N38 Series Male Connector - Turn signal
Iwiss Crimper for weather pack connectors this is the crimper I use with them its inexpensive and gives good crimp results, it crimps the weather seal separately from the wire  making it a little easier than the ratcheting type
Edited by ClutchXT
clarification
