Bargain rescue handles for £24.00 a pair.
TonyVito
Tried and tested in deepest Wales these rescue handles do the job so this is what you need; pair of pull handles from Specialized horse box components,
Part code H3p these have a steel core with thick plastic outer, the hole centres match the t7 tie-down bobbins,  4 no M8 socket head button screws 55mm L
4 no M8 aluminium spacers 20mm L, I got these mail order from GWR Fastners.
To fit the handles you need to remove some of the plastic coating with a file or Dremel to allow the handles to sit in the recess this only needs to be done to
what will be the underside of the handles when fitted. So now remove the tie-down bobbins, use the M8 spacers and screws to fix handles and your done .
  • Like 7
  • Thanks 2
