Changing sprocket size
Desert rat
Has anyone had any experience changing the sprocket size? I don't need to go 40 mph in 1st gear. I need more power to climb hill, go through sand, and any other challenges I might find riding the BDR. I just finished a ride from the Arizona southern border to the Grand Canyon. I may have burnt up the clutch, with only 2500 miles on the bike. My local dealer can not find a smaller front sprocket or a larger rear for my bike. According to them, no one makes one at this time. The only option the have is to replace both sprockets and the chain with a 520, a smaller chain.
I actually felt the opposite and went up a tooth in the front. Wanted to bring down the cruising RPMs at highway speeds, and I've never thought there to be a lack of low end power.
But yes, as TimmyTheHog mentioned, the front sprocket definitely is compatible with MT-07 sprockets. Probably the rear as well. I bought a Vortex front sprocket.
I noticed on the boano racing site they only sell a 48 tooth rear sprocket.  I might try that next but I don't really have any complaints with the stock gearing for what I do. I rarely even use 1st gear. Might make 2nd a little nicer though?
Teabag, I don't know how old your post is, I don't see the year, only the month. I just got my gently used 2021 2 weeks ago.
I  assume there was plenty of clearance for the larger countershaft sprocket? Mine will be on the tarmac 85% of the time, no hard core off roading  on a 460lb 10k bike for me. 🙂   That's what used WR's are for.
Edited by forcefit
Same with me.  Stock was too low.  Got an MT07 front sprocket and it's much better.
Yup, no issues with clearance on the sprocket guard at all!
So I went up to a 16T early in the spring when I fitted a new chain, and when doing a bunch of single track/rock riding/mountain climbing, the engine powered through nicely. Was maybe a bit harder than normal on the clutch, but again, no issues. The 16T makes it much more comfortable on the highway.
