Green chili uprising or wolfman unrack
Matt88-8
I currently have the mono rack on my T7.  It works well for day stuff but is really lacking for camping trips. I want something light and removable that holds dry bags.
Has anyone used the Green chili adv uprising system or the wolfman unrack base on the T7?
Thanks in advance.
  • 6 months later...
Thanks in advance.
You may have already made a decision, but I can offer some feedback on the Wolfman system. I have the B-base with 20L Rollies from my last bike. This setup fits nicely on the T7 also, so I’ll keep it for camping trips.  I strap a 30L dry bag in the middle for a total of 70L.
Everything is heavy-duty, stable, and holds up to crashes.  OEM muffler clearance is fine.  You can run it right on the pillion seat, no side or rear racks needed.
The bags are hard to get fully air-tight.  No issues with rain entering, but if you went down in a water crossing I’m not so sure.
The slots on the bags that look like Molle are not quite the standard Molle size and are oriented 90 degrees off from the direction I would find useful.  Adding small accessory pouches can be done but it is not clean and tidy.
The bags are not quickly removable from the base, so I leave them attached at camp or remove the entire setup if I can’t park nearby.
My buddy has the Mosko Reckless 80 on his T7 and it is better in ever way - except price.
If I were shopping again I would also take a look at the Tusk setup.
I am away from the bike today but I can provide photos if helpful.
Thanks for the review.
I did end up with the green chili adv kit.
Unfortunately I didn't get a chance to properly use it before winter set in,but my test run with it seems very promising.
