acessories central stand OEM yamaha tenere 700
pedrocorreia93
Should all be available in the yammy parts list at the dealer bud, just save a few pennies with your own nuts and washers that are available off the shelf. Found a good used incomplete stand eh? Nice one.
Did you get the installation instructions with the stand? You'll have a much easier time of installation if you follow the instructions in order. You'll also need the parts list from the instructions in order to get everything you need. If I was in your position, I would source everything OEM as most of the parts are unique to that stand. At that point, you might as well get the nuts and bolts OEM too.
