Where to buy the male auxiliary connector to attach to front right or left open white connectors ?
NeilW
50 minutes ago, roygilbo said:
I was thinking how to accomplish that.  I can adjust up and down, but how did you accomplish the slightly left and right?  (If I am reading you right?)
What mounts do you have ? Mine swivel. I originally mounted to the plate under the crown but moved them to the upper crash bars.
Ah! Mine are mounted under the triple clamp on the supplied mounting “plate”.   Tightening the light onto the bracket fixes it in one position.  As mentioned, I can adjust the beam vertically, but not horizontally.
I seem to recall that they are mounted with the Cyclops logo up for the beam pattern. I wonder if you flip them over if they will have a different beam pattern. Can you call Cyclops and ask. You will get a knowledgeable human on the phone.
  • 9 months later...
On 5/6/2022 at 11:44 AM, tenerecanada said:
Always! Anyone else?
Hello,I will also take a couple if you still have stock.
Thanks, Ron
Thanks, Ron
 Apologies Ron - I am all out. I have edited the original post.
would you happen to have a part # and where i could source one?
Thanks, Ron
Thanks, Ron
https://www.aliexpress.com/item/32657437642.html?spm=a2g0o.order_list.order_list_main.10.30511802Q3aSB7
Won't come too fast, but certainly the correct ones. Someone may have the universal name for them which may help you source them closer to home.
