J-Tech Tail Tidy
Lewie
This arrived yesterday so installed today
very compact and fits like most of the others on the market - feels very strong
it’s supplied with some spacers for the original indicators, a small stick on reflector, cable ties, 4 larger washers and 4 SS nuts and bolts- I think these were to bolt is to the underside of the bike but I used the originals
easly fitted in under and hour and sub £50
ive ordered an 8x6 ‘show plate’ to complete the look and I’m making a ‘guard to fit underneath to keep the mud out
sourced some thin black plastic
They have a website but also sell via eBay and Amazon
Unrivalled Quality Tail Tidy to Fit the Yamaha Tenere 700 2019 - 2022 Designed & Engineered by J-TECH Superior Quality & Strength, Powder coated, finished in a Durable & Stylish Matt Black Coating. Comes with - - PLUG &...
Edited by Lewie
Well I’ve added this piece- think I’ll pop a nut and bolt or a fir tree plug through where it meets the tail tidy
Edited by Lewie
did you have to take all the back end to bits  like other tail tidy fitting....i live in hope😉
I did but to be honest very easy and in under an hour with 2 cups of coffee
No kidding on the oem Yamaha tailpiece(s)....freakin ridiculous amount  of pieces and fasteners and plastic bits....was like a magic trick where Shet just keeps comin outa the hat.... LOL
I used a chinese tail tidy...aliexpress i think.  Worked good and is turdy...a lil too abbreviated IMO...I am going to add a plastic piece under there like you have done to deal with spray....and keep Shet outa the tail section
Good idea🤟
Hello did you have to cut and carv up the oem numberplate holder to fit it ? Thanks
No didn’t cut it at all just removed some of it
I've got a tail tidy for mine a j tech one and I didn't want to cut and carv my oem number plate holder up I'll get a pic of mine and post it on here
Is this the same or similar tail tidy to the one you fitted to yours
Yeh looks the same
Thanks again for your help Lewie
I think I have some of the plastic I used to make the splash cover under the rear
yup i got a Jtech TT on my WR and it's brilliant. The only thing i found is that it leaves a gap on each side communicating between the outisde and the inside of the tail, hence i stuffed some bubble wrap inside after soaking the whole rear frame with anti corrosion.
