Pannier rack compatibility
palada
What pannier racks are compatible with the SW-Motech topcase rack? Anyone know? Other than a SW Motech rack, obviously.
I'm looking at either Outback Motortek or Hepco Becker racks but I haven't been able to find info about compatibility. TIA.
Edit for update: SW Motech rack does work with Outback Motortek pannier racks. I had to make two adapters on the exhaust side so that it would clear the exhaust. One is to move the front mounting point about 3/4" out and on the rear to add 20mm to connect the rear bar. Not sure if this is necessary with the stock can, but I have a Leo Vince on mine. Hope this helps someone else.
Edited by palada
new info
  • 4 months later...
You helped me! I have the SW motech adventure rack up top and I want the outback motortek panniers.  You're saying I don't need to use any spacers on the non exhaust side?  Then is the back on the exhaust side 20mm more than the front at 3/4 of an inch?  Thx
Edited by l3ULLDOZER
