Oxford heated grips - glue/ position
Lewie
13 hours ago, Sweden said:
I think the cable outlet was really bulky on the oxford grips. Had to double check on the clutch side, so the lever movement wouldn’t get affected.
This Exactly!!
On 5/6/2022 at 11:30 PM, Rider 101 said:
I'm considering these for the short Australian winter instead of fitting heated grips.
https://www.zarkie.com.au/product/alt-battery-heated-gloves/?v=3a1ed7090bfa
Check the battery life. My Klim Battery gloves will go 6 hours on low, 3 hours on medium and 1 hour on high ( roughly). You can carry extra batteries but why not get wired heated gloves- they never run out of juice. I went with heated "wraps". They velcro wrap to the outside of the grips and come off when the weather is warm. I couldn't run them on "HIGH" even at -2C because it was just too hot.
I used Motion pro Grip Glue on my OEM Heated grips and failed HARD. Its like there is no glue at all.
If there was a void it probably didn’t fill it
What i used in past was gorilla glue, however need make sure surface is nice and rough. One time i had gorilla glue the heated broke the bond as I left the inside of the grip smooth so there was no mechanical bond.
this time i didnt use any glue,
installed grips, wired them up, then took them off and wrapped the clutch bar in a Strong flexible Gorilla tape (2" wide so get goo single layer wrap) https://www.amazon.co.uk/gp/product/B0B1N94H4L/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Then as grips heated up i slid them on gentley twinting 1/2" left and right to avoid ligting the tape
they are solid as a rock now and can be taken off in future if needs bit with some twisting and pulling
the Koso throttle grip was already a tight fit on the throttle tube and has not moved
Edited by john_aero
I went with removable heated wraps. $30, quick install and Removal, they work great.
2 hours ago, Oxxa said:
At that point i will just throw on my Barkbuster BBZ
https://barkbusters.net/products/bbz/
I have the ODB brand-  they are great down to 38 degrees but when I rode in 28 degrees ( -2C) I needed heated grips too.
Good to know, thanks!
