D.I.Y. Garmin Zumo (395LM) mount over the dash board
Totti
19 hours ago, Motoadventure said:
Top one where did you get the electrical connections from?
Mick
Bought them from eBay, from this seller :
But there are any others also.
Remember to order some extra pins! The first one gets ruined, at least I ruined it.
The 10A connector in the bike is called Sumitomo mt3. Don't remember is it a male or a female, sorry.
Thanks I wired mine into a box but always handy to find out the propper connectors.
Cheers Mick
Another couiple of photos of my Fuzeblock. looking at possibly putting spot lights on and your connections would be ideal.
Thanks Mick
Edited by Motoadventure
Hi I got it from Nippy Norman’s if you have a look on their website. The red and black wires to to the battery and the feed I think went to the blue indicator wire (I will check and let you know) the box is very well build unlike the Dinally power bud I had which fell apart after 2 trips. Cheers Mick
Whoa,  I just saw this and 5 minutes ago ordered the Denal PowerHub 2.
:classic_huh:
Might be a while before it falls apart with no bike yet.
:classic_rolleyes:
Hi, just to confirm is this the plug I need to connect heated grips and a GPS
MT07 2016-18. MT07 Tracer 2017-18. MT09 2014-18. MT09 Tracer 2017-18. MT09 SP 2018. YAMAHA Auxiliary DC Power Outlet Connector x 1. Photos from multiple angles have been supplied to help you identify your connector.
Cheers
Scott
Cheers
Scott
To get someones attention, put an @ before their username.  Like this @Totti   If they have their notifications set to email them, they will get an email that someone tagged them and come see your post.
Cheers
Scott
Week ago, I connected Oxford heated grips to the outlet-connector which is under the right side panel by the fuel tank. For heated grips you need 3-pin connector, but actually we use only two pins.
Edited by slawmir
 EU-Dudes could also order here:
X-Mas, Motorradelektrik, Digitalarmaturen, Elektrik, Zündung, Vergaser, Motorrad
They also ship world wide. Site unfortunately only in Austrian/German.
But they have nearly all connectors listed.
Edited by bikeever
Cheers
Scott
That's the right one for GPS, as mentioned already by @slawmir, You need a three (3) pin connector for grip warmers.
Thanks for the help I bought these in the UK and all worked well
Sumitomo MT 3 Way Tri Waterproof Sealed Connector Pair With Pins & Seals
