12V Aux power outlet
Dirtbandit
So I installed the 12v auxiliary power outlet with volt meter. Was not a fan of the fuse being hidden behind the fairing, so I came up with a little hack. Made an access port and utilized the original rubber plug to plug the new access hole. Hope this helps someone.
Very good
did that negate the need to remove the whole front end of the bike to tighten the nut underneath?
Hey Lewie,
Well I had to disassemble the headlight, dash speedo, windshield and all that stuff for the install. For a better answer, yes now I can access the mounting nut for USB through the new access hole. Should make replacement very easy if ever needed?
Edited by Dirtbandit
