  • Popular Post
I had a little time and decide to make a video to show how to remove the fuel tank on the T7.
It's easy ! πŸ™‚
Access at spark plug is a little bit more difficult because there's the ABS box to remove , but it's not like on the LC8 ktm.. πŸ˜‰
Β
sorry it's in French, bit you can see that's easy πŸ˜‰
Β
Β
Find "mobylette rollers" on social medias ! πŸ™‚
I have subtitled the video.
It's perhaps not perfect , sorry ! πŸ™‚ πŸ˜›
i like the cat - j'aimeΒ bien le chat.Β
thanks for posting. the tank is the only thing i have not yet taken off. will do so soon because i will try and delete the abs pump. i will modify and go back to conventional brakes and a single brake rotor in the front wheel.
Β
best regards from the german outback,
wolfram
  • 6 months later...
Can I get access to the coil pack without removing ABS unit?Β
Quickshifter might be on its way πŸ€”
  • 3 years later...
Does the tank need to be drained of fuel? Or can the lines be disconnected without need to clamp off the lines?
Β
No need to drain the tank, you can just disconnect the line under the tank...it's a 'quick connect' fitting.
