Supports compatible w/ OEM rear supp
Marcio87
Hello everyone. I have the yamaha OEM rear support and top case in my T7, and I've been struggling to find a compatible side support for cases/soft bags. I already searched a little everywhere and it seems that no other brand has a compatible side support. It seems I will have no other choice than go reckless or get the also OEM side supports. I found a brand, Batanga, that apparently does one but they are unresponsive so not sure of they are stll active.
Does anyone have any suggestion?
Thank you for your help.
I’m sure givi should fit. There’s a load of info on here somewhere. It’s probably one of our biggest issues.
Andystrapz frames fit for soft bags. Not for case use though.
Hi Dougie. The givi one need some grinding/cuting. Found a video of someone adapting it in YouTube:
I have not found any solution in the forum so far, but will keep digging or go for the mosko reckless system.
Thanks!
