Wheel Sensor ABS Rings
roygilbo
Go to solution Solved by Ray Ride4life,
Hi all,  the Yamaha manual says to put new bolts in when replacing the Wheel Sensor Rings (bought some from off-the-road.de).
Question, is this necessary (can I not reuse the existing?) and what size are they?
Thanks!
  • Solution
Nope, just to sell you very expensive bolts.
I never changed any bolts on any bike in almost a million kilometers unless they are actually damaged or just plain ugly next to perfect paint or whatever.
Thank you!
Clean bolts of old thread lock with wire brush. Clean hole threads with a tap. Use small amount of thread lock when refitting.
