Gilles AXB Chain Adjusters - anyone?
JB700
What's wrong with the OEM?
If you want to get rid of your money I can give you my bank number.
There was a group buy on here, last year.............so just wondered
Main issue for me, is that the oem adjuster block (mine has a burr & axle doesn't sit tight to the adjuster, but @ 30 degrees) is soft and the axle can spin, wearing into the adjuster block when tightening the axle
Plus the adjusters looks to give finer adjustment increments than oem
OEM adjuster blocks (no bolts) are£62 for a pair, in UK from Yamaha, if they need replacing (seen it happen to a few T7's) and these are £86 pair including bolts, so hardly expensive extra, for precision German engineering items and they look trick too
Edited by JB700
Main issue for me, is that the oem adjuster block (mine has a burr & axle doesn't sit tight to the adjuster, but @ 30 degrees) is soft and the axle can spin, wearing into the adjuster clock when tightening the axle
In that case.... Thought it was for the bling.
