Best swingarm clearance? HPcorse vs Mivv Dakar
Oxxa
I see reports on another post of problems with Mivv Dakar and that the new pipe version fixed the issue.
Perhaps someone else can post HP Corsa clearances, but clearance for the MIVV with the swingarm, while on the center stand & over the full 200 mm of travel (swingarm brake hose/cable guide contacts pipe @ 165 mm) + oem exhaust hanger can be viewed on my blog here on my 20221 T7 :
Yamaha Tenere 700, Yamaha Super Tenere 1200 ES, Ride Reviews
Already read your blog. Thank you for it, helped a lot.
is there a hazard for the hoses? Or its just when bike is on center stand?
The only hazard I see is potential damage to the MIVV mid-pipe from contact with the hose/cable guide &/or swingarm if the guide were to be removed.  I flattened the forward part of the guide to be more parallel to the swingarm & then raised the muffler 10 mm on the mount which netted 205 mm swingarm clearance...so it should be ok now for the oem full 200 mm of travel...but disappointing the MIVV did not sort this out prior to release of the system.  The revised pipe that a few have posted pics of seems an odd fix as the bend of the mid-pipe that makes contact with the swingarm has not changed much, but then goes in different directions where it connect to the muffler requiring a different mounting plate & the middle portion seems to be a smaller diameter (perhaps to create more clearance with the oem exhaust hanger)...so am not convinced it is actually the correct pipe & if it is it changes the aesthetics negatively imho.
Edited by prowlnS10
It sucks that you have to do these mods considering that exhaust is specially built for t7.
If i go with Hp corse do you think i will have these problems? Can’t find much info on forums
Just got a HP Corse a few weeks back, and plenty of clearance near the swingarm. The fit and finish is very good, at first I was skeptical of the price, took me almost a year to finally cave in. I'll post pics alter when I get home.
If you have ADVSpec luggage racks it requires a new bracket. Like most of these high pipes, also a compatible tail tidy/signal setup
Thank you!!! Please do send me pics of the details and clearances.
i dont have any luggage racks.
Anyone knows if hp corse or the new mid pipe for MIVV dakar works with the lowered tenere using thw 18mm lowering kit from yamaha?
I just curious why you are needing to know the clearance.  Are you going to widen your swingarm?
