Acerbis tank mod, what about breather tube?
Oxxa
I bought the Acerbis tank and the locking cap which removes the need for a tube/breather. What do i do with the OEM breather? Close it airtight & zip it or leave it open?
Should be able to just leave it unless you want to rip it out. I'd cap it by running a small bolt into it to ensure it can't suck dirt and muck and make it easy to use again later if desired.
That's exactly what I did with mine.
you can also connect the hose of tank with the check valve.
but i recently removed the canister in full.  as i think its Shet and i think i notice difference in riding as well.
i don't have pug's for the connector on the fuel injectors. so i just connected both with  1 hose.  should take care of this as well.
