Posted May 3, 20232 yr Hello there, i just installed the Acerbis 22l tank, check pics for understanding my problem. It looks like it’s not in place exactly and I don’t know what to do, i tried muliple methods already and was only able to fix it slightly. the first time it was so bad, the big side fairings on the front wouldnt align in their respective bolt holes. any help? Edited May 3, 20232 yr by Oxxa
May 3, 20232 yr Community Expert Previous users have had to remove the pads from the inside of the side panels for a good fit. Have you removed yours?
May 3, 20232 yr Author 2 minutes ago, Dougie said: Previous users have had to remove the pads from the inside of the side panels for a good fit. Have you removed yours? Yes the pads are removed, it was impossible with the pads.
May 3, 20232 yr Just finished my Acerbis Tank install this past weekend. As stated above, pads had to be removed from fairings to fit properly. Even with pads removed, the fairings were still a bit tight when first re-installing. Sounds simple, but make sure both fairing tabs (upper and rear tabs) are lined up and slotted in their respective places for them to sit right against the tank and bike itself.
May 3, 20232 yr If it is all bolted together then live with it. I'll get a closeup of mine later today. Alcohol! No good story starts with a salad.
May 4, 20232 yr I've dealt with plastic tanks, acerbis, on other bikes. The key is heat, either a heat gun or hairdryer. Warm up the bits that don't fit right, put into place while pliable, and let cool in place. The heat makes all the difference between impossible and easy. Just don't burn the plastic nor your hands. 2006 R1, 2018 XR650L, 2022 T7, 2023 Desert X, 2024 WR450F, 2024 YZ250X, 2025 V2 final edition
May 4, 20232 yr Moderators 9 minutes ago, Hollybrook said: Maybe don't post it twice in the same forum? 😉 Fixed it. One post is sufficient so the other one got nuked. "Men do not quit playing because they grow old, they grow old because they quit playing" Oliver Wendell Holmes - Mods - HDB handguards, Camel-ADV Gut guard, 1 finger clutch, The Fix pedal & Rally pipe, RR side/tail rack, RR 90nm spring & Headlight guard, Rally seat, OEM heated grips- stablemate Beta 520RS
May 4, 20232 yr Author 6 hours ago, Toymaster said: I've dealt with plastic tanks, acerbis, on other bikes. The key is heat, either a heat gun or hairdryer. Warm up the bits that don't fit right, put into place while pliable, and let cool in place. The heat makes all the difference between impossible and easy. Just don't burn the plastic nor your hands. I guess thats their nature, i thought i was doing something wrong
May 4, 20232 yr It seems to me you can pull the tank forward a little bit, using a heat gun. Edited May 4, 20232 yr by 365moto.eu
May 4, 20232 yr Author 2 minutes ago, 365moto.eu said: It seems to me you can pull them back a little bit, using a heat gun. Where do i heat it up?
May 4, 20232 yr 5 minutes ago, Oxxa said: Where do i heat it up? I think you can heat the two brackets, or you can WD40 them, to push the tank forward.
May 4, 20232 yr Author 1 hour ago, 365moto.eu said: I think you can heat the two brackets, or you can WD40 them, to push the tank forward. Those brackets are not the problem. Underneath where the tank lays on the main frame is the resistance between the bolt assembly (under the seat) in the back and the bracket in the front
May 4, 20232 yr Moderators My new tank is waiting for me on my porch when I get home from work today. I will follow along and share any fitment findings I come across. Location: Central Ontario, Canada Riding footage: www.instagram.com/beefmoto Message me if you are close - let's go riding!
May 4, 20232 yr Fill it with fuel. Go for a ride. Over pavements, or whatever obstacle you call adventure. 😉 I recall mine being a twice fitment too.
May 4, 20232 yr Author Just now, katana said: Fill it with fuel. Go for a ride. Over pavements, or whatever obstacle you call adventure. 😉 I recall mine being a twice fitment too. Ok time for borat joke. The furthest i have gone it to the gas station coffee shop near my house. NOT
May 5, 20232 yr Amazing pics, way out of my league. Only keen eyes will notice the lithium battery and titanium axel nuts to keep the weight down… I’ve found heat helps the most, let it simmer on the driveway at 60 then warm with a heat gun. Rock crawling at 10 MPH with 98 degree engine temps should work too. Again, super cool pics, that ledge looks narrow. Stay safe.
May 5, 20232 yr Loosen it up again, put some WD40 on the rubberpad underneath the tank and push it forward. You can also remove the rubberpad or replace it with thinner rubber.....
