Coil pack won’t go all the way in? Help!
Oxxa
6 hours ago, Buggy Nate said:
Before you go levering against delicate and expensive electrical components, there is a much easier way. There is a drain hole for the spark plug tunnels located under the header pipes on most models.
A squirt with an rubber tipped air gun and a gentle twist of the caps will free the most stubborn.
A small squirt of contact spray on the inside of the plug terminal and some silicone spray wiped on the outside makes installation a breeze.
I have seen a fair few damaged coil caps from levers in 20 years spannering.
Thx for this.  Have to look at the motor for future reference.
On 4/30/2023 at 7:53 PM, Oxxa said:
The caps are impossible to get out, do I use penetrating lube under the dust seals?
Not impossible to get out, hard maybe.
Fish a length of nylon cord down from above and round the cap. Then wrap cord around a bar/piece of wood and pull directly up.
