This topic contains 34 posts. A summary containing the most significant posts is available
Im looking to downsize my tool roll and am in search of the smallest axle wrenches, something similar to this picture.
I keep searching but and all results are 10 inch+ long wrenches. Im not sure how to seach for it or where to find these small ones.
Lyndon probably had them custom laser cut.
You could buy slogging spanners but they might be a bit weighty
Found it, about. 5-6 inches
Product code: 9900627000
wrencheye27mm_medium9900627000-01_116e.j
✓Good to order: WRENCH,EYE,27MM ✓Manufacturercode: 99006-27000 ✓Quality part
You could probably do your own easy enough if you can’t find them. Start with good tools though, and cut them down, for use with a good fitting extension that works on them all /or most. Or there’s a good combination tool for wheels on here. Sorry can’t remember which shop built them.
See if they have an extension. The Honda toolkits come this way. Or build your grip like a tyre fitter. 😁🍺
I think 6 inches is enough because I have the rally raid spanner and its not much longer and it works fine.
Is this the tiniest I can make it?
- 27mm wrench 5.5 inch long
- 22mm wrench 5.5 inch long
- motion pro hex adaptor 22mm wrench to 19mm hex
https://www.amazon.com/Genuine-Honda-22mm-Wrench-99006-22000/dp/B078F1N8GD
Motion Pro - High quality cables, tools and controls for motorcycles, ATVs, snowmobiles and personal watercraft.
Yamaha Ténéré 700 Wheel Service Kit This kit includes all tools to remove and install front & rear wheels of the Yamaha Tenere T700.
I think 6 inches is enough. But I’ll ask the wife. She may disagree. 😂
@Oxxa that wrench is about 4" from the center of the bolt to the end of the wrench.  The torque spec on the axle bolt is 77 lb-ft, so it would take about 230 lbs of pressure on the wrench to tighten to spec and more to break loose the bolt after it has been torqued.  How do you plan on doing that?
That is larger
I dont torque spec it. I hand tighten as much as i can it so i am able to do it on trail
Edited by Oxxa
This one?
Our own design of heavy-duty axle spanner allows you to remove both front & rear wheels from Yamaha T7 Tenere, as there are no suitable tools supplied with the OEM toolkit. Featuring a special 27mm socket on one end...
3 minutes ago, AZJW said:
This one?
I have it, takes way too much space in my tool roll because of is shape and thickness
Yes but at that point its taking more space than what i have now
Edited by Oxxa
18 minutes ago, Dougie said:
I was thinking along these lines @Oxxa   Like in the fireblade tool wallet.
These work well enough and are supplied in a TON of OEM kits.  The photos the op had at the beginning of this thread are clearly designed to be used with an extension like the one you linked to as well.
Edit:  I usually break loose rear axle nuts with one of the stubby tools shown+Extension+Foot pressure.  No way you'd get an axle tight enough to be safe or loosened using a stubby alone with no extension.   For the front axle I use my KTM spark plug wrench (very compact) as the toruq on it is not nearly as critical since pinch bolts are there to seep it from spinning out.
Edited by Windblown
since T7 axle nut is deeper in the swingarm. Do you think those 5.5 inch OEM ones can grab it? or it needs to be like this like the RR spanner
Edited by Oxxa
It looks like there’s enough meat on the nut sticking out to get it on there. Only checked an old photo though. Not been out to measure her.
Here is a photo of what I use for the front & rear. As long as the outside diameter is small enough to let it get on the rear axle nut it's workable. I've pulled and installed the wheels with these a few times.
How can i search for that small front wheel tool?
Search for KTM spark plug wrench (And it will work on the T700 sparkplugs as well).
KTM #77229072000
Edited by Windblown
KTM #77229072000
But you use that as a 19mm hex for front wheel yes?
thanks
thanks
Yes.
5 hours ago, Oxxa said:
That is larger
I guarantee you that you will not find a lighter kit of this caliber anywhere in the world.  The only drawback is the price.
Yamaha Tenere 700 tool kit (2)
I would also suggest you level up to the tire repair extension kit.
Tyre repair tool kit
2006 R1,  2018 XR650L, 2022 T7, 2023 Desert X, 2024 WR450F, 2024 YZ250X, 2025 V2 final edition
