Handlebar risers
Redneckj
I ran across this set of unique handlebar risers.  Has anyone tried the set of bar risers yet?  Spendy yes, but all the cool stuff is expensive.
verstellbare-lenkererhoehung-fuer-yamaha
High quality adjustable bar risers for Yamaha Ténéré 700 CNC milled &#9989 engineered in Germany &#10144 fast shipping options &#9989 TÜV approved
SW-Motech have a similar product, a little bit cheaper:
LEH-SW-LVV-28-SW-SW-Motech-Lenkerverlegu
Die aus hochwertiger Aluminium-Legierung gefertigte Lenkererhöhung versetzt den Lenker um 28 mm nach oben und je nach...
I think it might be a cool thing if you need to dial in your bar position and flipping the OEM riser (as I did) doesn't give you sufficient offset or too much offset.
I can't believe SW motech was too lazy to make the mounts round.  It will store dirt like crazy.
Two possible reasons: Either it's a generic picture, or because of max compatibility with different bikes. Probably the latter...
Moved from General Discussion
