Posted May 14, 20232 yr Made a custom radiator guard today out of wire mesh that cost a total of $2.38 and 15 minutes to install. Just couldn’t justify $100+ for a guard. Install was simple, cut out a piece of wire mesh at 12.5”W x 7.5”L. Removed the OEM plastic louver and drilled four small holes for the top ties to go through. Placed the wire mesh on the back side of the louver and zip tied each corner. Then used three zip ties in the center of the louver to stiffen up the wire mesh. Re-installed louver on the bike and that’s it. A simple guard for some small piece of mind.
June 25, 20232 yr On 5/13/2023 at 6:20 PM, Ghost775 said: Made a custom radiator guard today out of wire mesh that cost a total of $2.38 and 15 minutes to install. Just couldn’t justify $100+ for a guard. Install was simple, cut out a piece of wire mesh at 12.5”W x 7.5”L. Removed the OEM plastic louver and drilled four small holes for the top ties to go through. Placed the wire mesh on the back side of the louver and zip tied each corner. Then used three zip ties in the center of the louver to stiffen up the wire mesh. Re-installed louver on the bike and that’s it. A simple guard for some small piece of mind. I'm probably going to do something pretty similar. Have you had any issues or drawbacks to this design? The only thing I might do differently is put the mesh on the front instead of the back, just to protect the plastic guard itself too. Any reason not to? Thanks!
June 26, 20232 yr Author 2 hours ago, a.potato.rider said: I'm probably going to do something pretty similar. Have you had any issues or drawbacks to this design? The only thing I might do differently is put the mesh on the front instead of the back, just to protect the plastic guard itself too. Any reason not to? Thanks! No draw backs at all the last month of riding. Rode through some gnarly grasshopper patches on the road and it stopped all of them from bending/hitting the radiator itself. I put the mesh screening behind the plastic guard purely for aesthetic purposes vs the front of the plastic. Wouldn’t matter either way in my opinion. Best of luck!
June 26, 20232 yr 7 hours ago, a.potato.rider said: I'm probably going to do something pretty similar. Have you had any issues or drawbacks to this design? The only thing I might do differently is put the mesh on the front instead of the back, just to protect the plastic guard itself too. Any reason not to? Thanks! Just for info, I did the same, 22k km ago and didn't had any issues.
