Camel ADV & Hp Corse turn signal issue
Oxxa
Hi,
i have about 4.5 centimeter space between the metal bracket and the exhaust, i found these turn signals that are exactly 4.5 cm.
you think this will work? Check attached pics
thanks
EL-BL-X2-LED-Blinker-X2-schwarzes-Metall
Sehr edler und hochwertiger LED Blinker mit Gehäuse aus schwarzem Aluminium mit leistungsstarker und ultraheller SMD LED Technik. Sehr…
I don't have the Camel one but with mine I could bend the mounting tab to make clearance.  I'd suggest to use short lights and bend the bracket.
How much space do you have between the bracket and the exhaust?
I have ~3/8" 10mm gap.  The exhaust muffler at that point stays surprisingly cool.
Great help, thanks
I drilled new holes
