Yamaha Tenere 700 Tightening Torque Specs
Cruizin
Nice.
2 questions.
1. Has anyone an information about general tightening torques? This should be an entry point in service manual.
2. How can I find tightening torques for subframe mounting points on this picture?
Cheers
Pit
5 hours ago, Leocratus said:
Nice.
2 questions.
Cheers
Pit
Have a look at what size the mounting points are and compare to above chart... This chart gives you torque spec in relation to size of bolt/nut used : M4/M8 etc...
Aleks
Aleks
I was trying to do so earlier but it's not quite clear since in my case there are M8 sizes and the torque values from 7Nm to 28Nm. My suspicions are leading me to "lower bracket pinch bolt" and "upper bracket pinch bolt" since the number of screws is matching. If anyone can identify this,  it would be really nice.
Cheers
Pit
Wow @PJS it is what I was looking for. Do you have maybe rest of the service manual?
Cheers
Pit
  • Cruizin pinned this topic
On 2/13/2020 at 3:30 PM, Cruizin said:
Thank you very much for posting this information. I have a Yamaha service manual ordered but it has not come in yet. Being a novice, would you consider the lower and upper bracket pinch bolts the triple clamp pinch bolts for the forks? Thanks you!
  • 9 months later...
Holy pregnant cow with twins, Batman! That is so good and convenient. You rock dude!
The oil drain plug value is incorrect, some have stripped theirs at 32ftlb, 16 ft lb is the new recommended.
  • 7 months later...
