Installi9ng Garmin GPS on cross bar
Allen Kelly
Hi all, I have just spent the morning installing and mounting my Garmin Zumo 396 on the cross bar. To do this properly I removed the right side tank plastic and the top windshield. I used the heated grip wire not the plug which I left just in case I decide at some stage to install the heated grips.  I removed all the tape and cut into the plastic sleave to expose the wires. There 2 red/white and 1 black. You only need 1 R/W and the black. Positive to R/W and negative to black. I used some Scotch extreme grip tape to hold the regulator up under the tank. Then fed the cable through to the cross bar. I used some clear hose on the cross bar to size it up for the Ram Mount fitting it also adds extra grip so the mount is very firm. My Zumo is fitted with a lockable device for security purposes from (www.zumolock.com) I then tested that it operated correctly (and it did) All that was left to do was to tidy up the wire and reattach the side panel and windshield.
thank you!
