Center stand spring mount
Totti
Installed the H&B center stand today. Don't know if You figured this out, but here is how I mounted the spring.
First tried it with pliers, but I wasn't strong enough. So I got some string and a piece of wood. Much easier this way.
  • Like 7
  • 10 months later...
Hahaha, wish I had seen this yesterday....finally got it on with a ratchet strap, spring puller and lots of cursing!
Any idea if removal is as difficult/frightening?
Removing can be done by either way: yours or mine. 😁
I couldn't locate here on the forum if this had already been posted, but here's another method. As Totti basically said, more than one way to skin a cat.
Jump to 1:45 to get to the meat and potatoes section.
I did it one spring at a time and used a large 1/4 wide tie wrap to stretch each separately..
On 1/3/2021 at 9:42 AM, Atomizer said:
Super easy doing one spring at a time with hooked spring tool....
Doing one spring started to straighten it out..
