Yamaha Factory quickshifter
razz007
Is awesome , fitted for nearly a week and it’s great , keep her pinned through the gears and away you go , very smooth from 3k upwards even when not flat out  . Hopefully I’ll get down a lane after work tomorrow to see how it feels off road . We got a monster storm coming thru , so the lanes could be interesting
first time i hear of it, you still have the clutch tho ? like to start and for low speed in technical stuff ?
Clutch remains. Necessary only for take off. Of course can use when ever You want.
Which T7 model?
13 minutes ago, Krachun said:
Which T7 model?
Standard version with the tft screen
Still use the clutch for launch and when ever you like
Thanks, I saw that in one of your earlier posts that it's a 23.
What Yamaha part number did you use?  Where is the bike side connector located?  Thanks!
This is the P/N for my '24: BNW-E81A0-V0-00. Expected delivery on Monday.
I just installed mine yesterday and I'm really impressed. The only other quick shifter I've ridden with was on my Husky Svartpilen and this one is absolute butter by comparison. It seems a little exposed to damage and the top of the linkage is pushed out further from the bike, but carrying the stock linkage as a spare on a trip seems like best practices anyway and it takes up almost no room.
Thank you very much for sharing info about QS !
May I please ask you ist it possible to take a photo of wire connector for QS and possibly color of wires ?
Thing is , I got myself T7 with FTECU flash and QS is enabled in flash.
Also, recently I got myself cheap QS sensor from aliexpress, witch is N/O type (most of them are).
So I am thinking abou experimenting with it and try it on my t7 !
I dont know where are wiring connections ? I have two spares connectors right behind that black cover where your wire goes but Im jet sure what are they for ?
Thank you very much
Thank you very much
I'm out of town for the weekend. I'll try to remember to grab a picture when I get home tomorrow.
7 hours ago, parkys100 said:
Does this fit a 2020 model please?
I can't imagine it does, only for TFT dash models so far as I'm aware.
It factory version only fits the latest version with tft screen .
Thank you very much
It’s the light grey two pin plug behind the black panel under ya seat , left hand side front . It’s got a blank plug in it . Tft model version only
That is a thing, I cannot find it. I have 2022 World Raid model (it has TFT screen).
There are blank two plus , black, each has 2x wires in it, they are over taped with black tape. Im thinking maybe that are the wires ?
Thank you
Thank you
I’m unsure of the world raid . This is what I removed to plug in the quickshifter . I sold my tenere yesterday , so unable to get to the bike now IMG_6792.jpeg.e4d98577413829ce5bd9b1fc88621a0b.jpeg
Thank you
No doesn’t fit first batch of world raids only any of them manufactured in 23
I was told that 2022 dont have prewired connector but one guy told me thats only wire is missing. All harness I could do by myself (going to ECU).
Also, my ECU is flashed with FTecu with QS
So I m just interested, color code of the wires that are going to that plug so I can exame wiring diagram and what pin uses on ECU.
Yes so basically you can’t fit factory quickshifter but you can fit other brands but at a much higher cost and will have to fully wire yourself
10 minutes ago, forty2 said:
Here it is:
Obviously I dont have it, but I have different ones (check the photo). Can I just ask one more thing, can you tell me those two wire going to connector , what are the colors ? (not the sensor side, other one)
Thanks !!
